View Trunks
Perform this procedure to view the MLT-based SMLT configuration.
 - Select SMLT.
 - Select the SMLT Info tab.
SMLT Info Field Descriptions
Use the data in the following table to use the SMLT Info tab.
 Name  |
 Description  |
 Id  |
 Shows the MLT ID for this SMLT Read-only.  |
 MltType  |
 Shows the MLT type of this trunk.  |
 RunningType  |
 Shows the SMLT running type.  |
